New robot options for material handling, palletizing
A high-speed, shelf-mounted robot for material handling provides flexibility and superior performance in high-payload material handling applications, while a four-axis palletizing robot has fast axial speeds and acceleration, which reduces cycle times and increases production output.
May 17, 2010
Both new offerings are from Motoman (Waukegan IL). The Motoman UP400RD material handling and part transfer robot boasts a maximum payload of 400 kg, and can work in tight spaces and service multiple processes. Key performance parameters are 3518-mm horizontal reach, 4908-mm vertical reach and ±0.5 mm repeatability. Optional MotoSim EG-VRC off-line programming software with virtual robot control simplifies programming and simulation.
The Motoman MPL100 palletizing robot, meanwhile, boasts a payload of 100 kg, and an extensive 3024-mm vertical reach providing for palletizing loads up to 2743-mm high on a 1066-mm pallet, or up to 2667-mm high on a 1219-mm pallet. Repeatability of ±0.5 mm is also delivered. The robot can service multiple infeed conveyors and up to four pallet-build locations. —[email protected]
