AGR INTERNATIONAL, INC.
May 1, 2000
Booth N-5350
What's Hot! AGR's CVIS Conveyor Vision Inspection System (Dec '99 PA, p 13) is a stand-alone 'machine vision' device designed to inspect plastic containers as they exit the blow molder on a flat top conveying system. The CVIS identifies critical container defects and helps monitor the performance of the blow molder. It can be configured to inspect critical regions of a container including base, sidewall, and inside finish, along with external finish dimension measurement. Unit is said to perform 100% in-line inspection at speeds from 150 to 300 containers/min (depending on configuration).
Existing Products On Display Also on display will be the BVIS Blowmolder Vision Inspection System (May/June '98 PA, p 28), which is designed to inspect plastic containers while they are inside a two-stage blow molding system at speeds up to 32,000 containers per hour. The BVIS can be configured to monitor one or all of the operator designated criteria. Circle 206
Key Contact David Dineff  Tel: 724-482-2163; Fax: 724-482-2767;
E-mail: [email protected];
Web Site: www.agrintl.com
