Compact sample conditioning cabinet
August 23, 2008
The Datacolor Conditioner is a compact sample conditioning cabinet designed as a cost-effective solution to control ambient conditions when color samples are measured. Originally developed for the textile industry, the Conditioner ensures that samples are conditioned to a fixed temperature and relative humidity prior to physical measurement of the samples. Conditioning time is 5 to 10 minutes. It also provides stable conditioning to light by supplying a stable, constant exposure to a defined illumination. The physical color of a sample can alter substantially when ambient temperature and relative humidity are not stable. Datacolor says that by using the Conditioner, color samples can be measured at different times and in different places without risk of variation or errors. The unit needs no special water for humidification, measures 834 by 1022 by 646 mm, and has an optional floor stand.
Datacolor, Lawrenceville, NJ
(609) 924-2189
www.datacolor.com
