Downsized two-platens
August 23, 2008
Electric screw drives are optional. They are said to complement the smaller Maximas? short tonnage-build time of about .5 second and their fast clamp speed of 1143 mm/sec, allowing simultaneous clamp, eject, and plastication. Mold height is set with the closed loop digital positioning of a single pancake cylinder mounted on the moving platen, reportedly a simpler and more accurate method than using the four transducers in four tiebar-mounted cylinders on other two-platen presses. Using a pancake cylinder is also said to reduce machine complexity and service/parts issues. The mini Maximas are also said to be very frugal when it comes to clamp-up oil requirements. All are equipped with Cincinnati?s Xtreem open-architecture, PC-based controls, featuring digital position feedback on clamp, injection unit, and ejector; fully programmable corepull on the moving platen; and optional Web surfing and e-mail capabilities. Cincinnati?s MeltStar barrier screw is standard.?CK Cincinnati Milacron |
