Micro-extruder tailored to run fluoropolymer tubing, devices
A new 16-mm micro extruder has been expressly designed to process fluoropolymers for miniature medical device applications such as fine wire jacketing for neuromodulation, microdialysis tubing and neonatal intravenous (IV) catheter tubing. American Kuhne Inc. (Ashaway, RI), which created the extruder, noted that these applications typically require an extruder that can process high-performance fluoropolymers like ETFE, PFA and FEP, at very low volumes down to 3.4 g/min (.45 lb/hr).
August 21, 2013
The company said that unlike most medical grade thermoplastics such as polyurethane, nylon and pebax, it is difficult to process fluoropolymers on extruders smaller than 16 mm because the special corrosion resistant screw materials that are used such as Inconel and Hastelloy have low torsional strength and are prone to break at diameters below 16 mm. The smallest extruders for these applications have traditionally been 3/4-inch (19-mm) machines. The benefit of a 16-mm extruder for micro extrusion applications is the 45% reduction in the minimum output rate and a short residence time in the barrel, which helps to minimize thermal degradation especially compared to running traditional extruder sizes of 3/4 inch (19 mm) and 1 inch (25 mm) at very low screw speeds.
