New metallized BOPP film designed to replace foil in stand-up and flat pouch applications
Toray Plastics announces to consumer packaged goods manufacturers and packaging converters the introduction of the new Torayfan PC5 metallized BOPP film, an ultra-high oxygen- and moisture- barrier film that can be used in tri-laminations, as a foil replacement, and as an overwrap lamination or wrapper.
February 4, 2014
The new Torayfan PC5 high-barrier metallized BOPP is said to be a durable, cost-effective replacement for foil in a typical paper/PE/foil/PE packaging structure. In addition, it is ideally suited for use as the inner barrier web of a tri-lamination in gas-flushed stand-up or flat pouches. It can also be used as a cold-seal layer and as part of a lamination for high-quality confectionery wrappers and bakery overwraps.
Advanced PC5 metallized OPP film is designed with an ultra-high-barrier layer resistant to crazing on one side. The other side is corona treated for excellent bond strength in cold-seal adhesive applications and in extrusion and adhesive 3-ply laminations. With its protection against oxygen and moisture in gas-flushed applications, PC5 film ensures that food manufacturers' products will stay fresh throughout shelf life. PC5 OPP film is available in 60 gauge (15 um) and is designed to run on HFFS and VFFS packaging equipment. End users and converters can now specify that Torayfan PC5 film be used as the barrier layer in laminations for a vast array of packaging applications, including cookies, snacks, specialty food items, dried fruits, pet food, powdered hot chocolate and cheese, spices, cough drops and more.
"New foods are introduced to the consumer daily and end users and converters want more than the packaging status quo," said Kerri Boyens, product manager of the Torayfan Division. "PC5 film is an innovative foil-replacement and barrier packaging solution that offers clear competitive advantages. It has superior oxygen- and moisture-barrier functionality, is versatile and readily available, and is an economical solution, particularly when compared with foil."
