New Rubber Processing Line Features Improved Feeding TechnologiesNew Rubber Processing Line Features Improved Feeding Technologies
September 1, 2001
September, 2001
Extrusion:New Rubber Processing Line Features Improved Feeding TechnologiesNFM/Welding Engineers' new Series II HRX rubber extruder line, developed with its European subsidiary, NFM IDDON, features a number of new design features, including a feed cylinder with hinged power-feed roller and extended feed liner. These features are said to provide for efficient feeding of rubber strip or granular stock. For units with a screw diameter of 90 mm or above, a water-cooled and/or independently driven feed roller are options. Each Series II HRX extruder,other than those used in silicone applications, are available with a high-intensity mixing scroll (HIM) and with pin barrel/screw concepts (primarily used on machines with a 90 mm or larger screw diameter).Machines are available with screw diameters from 38 to 250 mm. Modular construction allows for various L/D ratios and scroll configurations to suit all elastomeric materials and applications. A range of mixing screw configurations is also available.For pricing information, please contact company directly using our Key Contact Directory on p 70.NFM/Welding Engineers
Massillon, OH Circle 104
