PEEK into wear resistance
Wear-resistant grades of KetaSpire polyetheretherketone (PEEK) and AvaSpire modified PEEK resins are now available from supplier Solvay Advanced Polymers LLC (Alpharetta, GA).
February 3, 2010
(Alpharetta, GA). Targeting substitution of complex metal-based designs with rolling components for high-temperature friction and wear applications in lubricated and non-lubricated environments, the five formulations are anticipating use in seal rings, thrust washers, brake components, gears, and needle bearing replacements for the automotive, industrial, and heavy-duty equipment industries.
KetaSpire PEEK boasts a heat deflection temperature up to 315°C. In this product family, KT-820 SL30 is a graphite/carbon-fiber/PTFE-filled grade for non-lubricated and lubricated applications. In non-lubricated environments, it features a limiting PV value (contact pressure times velocity) of 75,000 psi x fpm and exceptional ease of processing, according to Brian Stern, senior global automotive market manager for Solvay Advanced Polymers. The line also includes KT-820 SL45, a carbon-fiber/PTFE grade for lubricated environments.
The AvaSpire line includes AV-755 SL45, a carbon-fiber/graphite-filled grade for high load-bearing applications in lubricated environments. Two carbon-fiber/graphite/PTFE-filled grades include AV-742 SL30 (high melt flow) and AV-722 SL30 (low melt flow) for both non-lubricated and lubricated environments. AvaSpire grades claim comparable strength and modulus, and equivalent or better chemical resistance vs. comparable PEEK grades at up to a 30% cost reduction. —[email protected]
