Roll Inverter Can Rotate Up To 60,000 lb Of Film/Sheet
November 1, 2000
Pentalift Equipment Corp.'s heavy-duty roll inverter is designed to safely rotate a 60,000-lb roll of extruded blown film or sheet 90 deg from a horizontal to a vertical position. Unit features dual direction, full load rotation capabilities and works via direct gear and chain-drive actuation.
The system features a 'power to release' safety brake system, which is designed to hold a load securely in any position at any point of rotation.
These units are highly customized; customers specify height, weight and diameter of the coil, as well as speed requirements and power supply. Pricing is based on these factors.
Buffalo, NY
