New type of vacuum resin dryer is said to increase molding productivity
Production-scale demonstration runs with a wide range of resins have shown that a new type of vacuum resin dryer introduced by Maguire Products exhibits greater throughput than originally specified and achieves required dryness in just 35 minutes after a cold startup, the company said.
January 29, 2014
The Maguire VBD150 vacuum dryer, originally rated for a throughput of up to 150 lb. (68 kg) per hour, exceeds 200 lb. (90 kg) per hour with hygroscopic materials such as ABS, acrylic, nylon, polycarbonate, polyetherimide, and PBT, according to B. Patrick (Pat) Smith, Maguire VP of marketing and sales. The dryer can reportedly deliver process-ready resin in just over half an hour, compared to a conventional desiccant dryer, which can take up to four hours to bring resin from a cold startup to a condition of readiness for molding saleable product.
Additional productivity enhancements are available with two features now available for the dryer: an "EasySlide" mechanism that enables the vacuum vessel to slide out, giving ready access for cleanout; and an optional hopper extension whose one cubic foot (0.028 m3) capacity extends the throughput of the dryer by 25%.
"Vacuum drying is six times faster than with desiccant systems, which not only makes possible much shorter cold startups but also reduces the risk of material degradation, since resin is exposed to elevated temperature for 80% less time," Smith said. "This remarkable drying speed is attributable to a far more efficient method for extracting moisture from resin pellets-so much more efficient that vacuum dryers reduce energy consumption by up to 60% in comparison with desiccant dryers."
The VBD vacuum dryer uses gravity to move material through three vertically arranged vessels, with the discharge of material from one vessel to the next controlled by slide-gate valves. From top to bottom, the vessels include a heating hopperthat brings resin to a target temperature; a vacuum vessel in which vacuum reduces the boiling point of water, causing moisture within the pellets to volatilize and be forced out of the pellet into the low-pressure environment surrounding it; and a pressurized retention / take-away hopper that is continually purged by a membrane air dryer to maintain the target level of dryness until the material is discharged. This system eliminates most moving parts, in particular the three-station indexing carousel mechanism of the Maguire LPD vacuum dryer introduced in 2000.
The new EasySlide feature involves the vacuum vessel, which slides out in the style of a drawer and is securely held in that position during cleaning. The feature gives access to the retention hopper as well as the vacuum vessel.
