Chillers target injection moldingChillers target injection molding
November 1, 2002
Designed with the injection molding industry in mind, the Model ACP air-cooled stand-alone chillers are equipped with hermetic scroll compressors and stainless steel pumps, frames, and tanks. Stainless steel evaporators are also used, and temperature control is via solid-state electronics. Other features include a hot-gas bypass, a water flow switch, a freeze thermostat, and non-rusting water piping. The key to the chillers is reported to be the design of their stainless steel brazed plate evaporators. If 85F plant water is available for the condenser, water-cooled units up to 10 tons can be used. The chillers use coaxial tube-in-tube condensers. Large units use brazed plate condensers, with optional shell-and-tube design.
1st Choice Portable Chillers, Markham, ON
(877) 513-8310; www.1stchoicechillers.com
