Combination line targets thermoforming packaging
April 1, 2007
To produce barrier films, processing lines with two cast film stations and an inline laminator are an interesting alternative to conventional coextrusion through a feedblock. This manufacturer is offering such a unit made up of three sections: a cast-film line processing nylon (PA) lamination film; a cast-film line producing polyethylene (PE) film; and a laminating station to join the PA/PE webs. The manufacturer say the biggest advantage of this line compared to a line with single-stage, multilayer feedblock extrusion is that all edge trim is recycled since in each section the edge trim is uncontaminated and can be fed back directly into the extruder. Layer-to-layer uniformity is said to be more precise since thickness gauges control the profile of the individual mono-layers. Thickness ranges for the PA/PE film are from 80-300 µm. Main applications of these barrier films are for thermoformed food products packaging and vacuum bags. SML, Lenzing, Austria; +43 7672 9120; www.sml.at
