DORNER MANUFACTURING CORP.DORNER MANUFACTURING CORP.
May 1, 2000
Booth N-8134
What's Hot! A new line of modular bolt-on accessories for conveyors is said to aid in guiding, merging, transferring and locating products. These accessories are designed to reduce engineering time and to increase productivity and efficiency for automation and assembly line applications.
The adjustable lane-guiding accessories are compatible with Dorner's 2100, 3100 and 6100 Series industrial flat conveyors and fit conveyors up to 24 in. wide. The guides are available in standard 1-in. increments and can be ordered to any length. The guides adjust easily for quick product changeover.
The 90-deg adjustable transfers are compatible with 2100, 3100 and the LPZ flat bed conveyors. They feature pre-engineered guided turns, which adjust to a variety of products. The kit includes the outside and inside turn guides, adjustable mounting hardware and extruded aluminum transfer plate.
Adjustable tie bracket kits include an extruded aluminum tie bracket, angle bracket, drop-in T-bars and attaching hardware. Brackets are available in 2-, 3-, 4-, 5- and 6-ft lengths and are compatible with both steel and aluminum support stands. They can be used in in-line, 90-deg and incline/decline conveyor applications.
The pulley transfer plate kits can be used with Dorner's 2100, 3100 and LPZ flat belt conveyors. The total package comprises an extruded aluminum transfer plate, required pulley tail plates and mounting hardware.
Existing Products On Display The LPZ is a versatile, adjustable-angle conveyor for a variety of material handling and packaging applications. The frame can be set up in a variety of configurations to fit manufacturing, assembly, or warehouse needs. Standard cleated and sidewall-cleated belt models adjust from a 25- to 60-deg incline; flat belt models from 0 to 30 deg.
Cleated belt models are available in widths from 8 to 24 in. with lengths available in 1-ft. increments from 4 to 25 ft. End-drive and center-drive flat belt models are available in widths from 3.75 to 40 in. Conveyor lengths are available in 1 ft. increments from 4 to 99 ft. Belt speeds range from 8 to 130 ft/min for loads up to 100 lb. Circle 246
Booth Personnel J. Downen, Ken Clough, Dan Reyburn
Key Contact Marilee Muth  Tel: 262-367-7600; Fax: 262-367-5827;
E-mail: [email protected];
Web Site: www.dorner.com
