Flat steel range expanded
November 10, 2008
?Now offering moldmakers a choice of more than 3000 available sizes, Hasco (Arden, NC) significantly expanded its range of flat steel products. The P5600 grade has been integrated into the higher-precision F range, and all dimensions are grouped together under one order number, making it quick and easy to find the ready-to-use sizes. Many new materials have also been added, including highly polishable case hardening steel 1.2162 and through-hardening cold work steel 1.2363, which is known for its extremely high wear resistance. Offering excellent machining properties, dimensional stability, and corrosion resistance, the prehardened and tempered chromium stainless steel 1.2099 is now also available as precision flat steel.
All the tolerances and dimensions conform to DIN 59350 and are oriented to practical applications. Hasco also offers its online ordering system at www.hascoshop.com at a fixed price, which doesn’t add alloy surcharges that other suppliers do.
?Hasco America
www.hasco.com
