Gets rid of flash in a flash, without the worriesGets rid of flash in a flash, without the worries
Mitchell's deflasher offers speed and accuracy.
December 11, 2008
New from Mitchell Inc. is its Model 242 vertical dual-head trimmer / deflasher designed for use with elastomeric, thermoplastic or bonded metal insert parts. The new unit is said to offer the speed and accuracy needed to reduce problems with breakage or compromise on critical part dimensions for cryogenic deflashing. The trimmer/deflasher is equipped with two digit-controlled oscillating knife blade units on top of a multi-task head plate. The blade angles are set by micrometer level in .1Ëš increments at ±45Ëš from the vertical with fast and easy adjustments. The trimmer/deflasher can cut parts from 1” to 9” diameters with a .002” repeatable accuracy. The head plate can be fitted with robotic loaders and unloading devices to dramatically reduce cycle times. It comes with digital touch screen controls and digital operating components, helpful for quiet operation, close tolerances, easy set-up and low operating costs. Other options are available. For more information, contact Mitchell Inc. (Elkhart, IN) at T: +1 574-295-3509; www.mitchell-inc.com.
