- Plastics Processing
- Injection Molding
- Business
- Auxiliaries
- Extrusion: Film & Sheet
- Extrusion: Pipe & Profile
Italian, Taiwanese firms join to serve China’s plastics extrusion market
A new joint venture is being formed in China by Taiwan's Shini Plastics Technologies Inc. (Taipei) and Italy's Syncro srl (Busto Arsizio) to serve the automation needs of processors of extruded products. The venture opens China's fast-growing market to Syncro's products while helping Shini expand its customer base, to now mostly injection molders.
April 23, 2010
Based in Dongguan, Guangdong Province, Shini-Syncro Extrusion Control Inc. will manufacture and provide products and services in the fields of gravimetric dosing and mixing systems, central conveying systems, film-thickness measurement and control systems, and central monitoring systems for extrusion lines. The joint venture will integrate the advanced extrusion line process-control expertise of Syncro with Shini's advantages of global marketing channels and low-cost manufacturing.
Shini's core business is the manufacture and sales of plastics auxiliary equipment including dryers, feeders and conveyors, dosers and mixers, mold-temperature regulators, granulators and recycling equipment, robots, and hot runner systems. As such, its traditional customers have been injection molders.
At the Chinaplas show held Apr. 19-22 in Shanghai, Shini unveiled a series of new products, including the SCD-ES "all-in-one" energy-saving compact dryer series, which integrates dehumidifying, drying, and conveying into a single unit. Especially suitable for processing hygroscopic engineering plastic materials, such as ABS, PA, PC, PBT, and PET, the series employs a silicone honeycomb-rotor. Shini also debuted a mold-temperature regulator that employs a magnetic pump in place of the traditional shaft-seal pump. Shini says the contactless pump is less prone to leakage and is also maintenance free, whereas the mechanical shaft seal of a standard pump normally needs to be changed annually. —Stephen Moore
