Polyamide inches in on LCP, PEEK territoryPolyamide inches in on LCP, PEEK territory
A new generation of automotive exhaust-gas recirculation temperature (EGRT) sensors is now being molded of Stanyl ForTii high-performance polyamide 4T from DSM Engineering Plastics (Singapore). Thanks to the very high temperature stability of Stanyl ForTii, the supplier reports that costs are being cut in the production of the sensors, without compromising on quality.EGRT sensors are critical elements that are employed to improve overall vehicle performance, monitor emissions and improve fuel efficiency.
Stanyl ForTii is reportedly able to withstand continuous-service temperatures up to 300°C, allows significant cost savings, without sacrificing thermal or structural performance. Alternative materials for EGRT sensors include liquid crystal polymer (LCP) and polyetheretherketone (PEEK), both of which are more costly.
In close cooperation with its customers, DSM's application development team identified the operational parameters for the EGRT application. Extensive prototype testing demonstrated that Stanyl ForTii has the thermal performance and mechanical properties required for the demanding environment in which the sensor operates.
With the appropriate design, Stanyl ForTii can withstand a temperature as high as 325°C on an intermittent basis and still retain all the mechanical properties required for this very demanding application. It also has the excellent chemical resistance necessary.
"Stanyl ForTii is not only significantly more cost-effective than PEEK in this application, it also offers shorter molding cycle times than alternative high performance engineering plastics," says Chris Scarazzo, Business Development Manager at DSM. "Until now, LCP and PEEK have been the default high temperature materials of choice for applications like this. Now, Stanyl ForTii will enable design engineers to specify a more economical material for very hot and aggressive environments."
