Optical sorter puts resin under magnifying glass
March 1, 2006
Optical sorting equipment capable of spotting material contamination as small as 0.1 mm in resin with a 99% effective rate detects black specks in resin used in optically sensitive applications like transparent film or optical-storage media. The system works by spreading the material stream over a conveyor so there is one layer, which passes under high-resolution cameras that spot contaminant materials as small as 100 µm.
Any defective granulate that is detected is blown from the material stream by a system of 256 high-performance jets, featuring a reaction time of less than 1 msec so that 4000 shots/second are achievable with total material throughputs of 2500 kg/hr being possible. Scan&Sort GmbH, Wedel, Germany;
+49 4103 800890;
