Plastics big winners at the DuPont packaging awards, part 9
Delivering soup to parts of Africa that don't have established distribution channels requires packaging solutions that extend shelf life. The new Mondi soup packet replaces aluminum foil with a co-extruded paper laminate and tailored barrier properties that protects the contents guarantees high shelf life. The Mondi soup packet also uses a special sealing polymer that allows sealing temperatures to be significantly reduced, resulting in much lower energy use and higher efficiency on the filling lines.
May 16, 2014
Delivering soup to parts of Africa that don't have established distribution channels requires packaging solutions that extend shelf life. The new Mondi soup packet replaces aluminum foil with a co-extruded paper laminate and tailored barrier properties that protects the contents guarantees high shelf life. The Mondi soup packet also uses a special sealing polymer that allows sealing temperatures to be significantly reduced, resulting in much lower energy use and higher efficiency on the filling lines. The elimination of the aluminum layer also allows the use of metal detection to ensure product safety.Click on the arrow below to go to the next slide.Soup Packet - Silver Winner
