Orifice Gate, Gravity Diverter Added To Line
May 1, 2001
May, 2001
Materials Handling:
Salina Vortex has added two new items to its line of materials handling equipment: the Hand Slide Orifice Gate and the Model Z Seal Tite gravity diverter (not to be confused with the Model Z-SL Seal Tite gravity diverter, Apr '01 PA, p 10).
Please contact the company directly for pricing (see the Key Contact Directory on p 39).
Orifice gate This manually actuated process gate is said to offer 'dust-tight' control of dry materials in gravity flow situations. It can be used on the inlet/outlet of hoppers, bins or totes where the use of powered gates is not feasible or desired.
The self-cleaning unit is available in sizes from 2 to 14 in. and it can be modified for various mounting options (a stud bolt flanged tube connection or optional bolt-through pipe flange connection). The orifice can be lined with aluminum or stainless steel and the standard 180 F-service can be modified for higher temperatures. Also optional is a 'Special Service Inlet' to protect seals when closing on material or when handling hard or abrasive materials.
Gravity diverter The Model Z Seal Tite gravity diverter is a clean-in-place unit said to allow for quick access for inspection and cleaning. Unit has a tight, durable vane seal, clean flow area and a 'live-loaded' wear-compensating shaft seal for handling dry bulk materials in gravity flow applications.
The difference between the Model Z and the Model Z-SL, is that the Z-SL is straight through with an off leg to one side and the Model Z has equal-angle dual off legs. Model Z is available in carbon or stainless steel construction with air cylinder, electric, hand lever or chain wheel actuators. Round transitions are also available.
Salina Vortex Corp.
Salina, KS
